Sienci Labs
    • LongMill MK2
    • Extension Kit
    • Laser
    • Gallery
    • LongMill MK2
    • Extension Kit
    • Laser
    • Gallery
Home / Can I add homing or limit switches to my LongMill?
Frequently Asked Questions
  • Frequently Asked Questions
  • Can I add homing or limit switches to my LongMill?
Yes, the LongMill supports homing or limit switches in a variety of configurations. General information about adding them can be found in our resources.
We also sell kits to help you add inductive sensors to your machine. You can choose one based on the model of your machine:
  • LongMill MK1, which uses standard aluminum angle
  • LongMill MK2, which uses custom aluminum extrusions
Previous Article
Can I use an alternative router instead of the Makita?
Next Article
What is the maximum feed rate for the LongMill?
  • Shipping
    • Where do you ship to?
    • Can I pick up orders from your office?
    • What are duties and taxes and how much should I expect to pay?
    • What is the size and weight of the LongMill in its package?
    • Why are some parts of my order separate or split up?
    • How can I get a shipping estimate?
    • How can I change, add, or modify an existing order?
    • Can I put a hold on a shipment?
    • Why do I need to provide my SSN, TIN, or EIN for US Customs?
    • I just ordered a LongMill! How can I get an update on when it will ship?
    • I have never used a CNC machine before? Will I be able to learn how to use it?
    • What software comes with the LongMill? What software can I use?
    • Can the machine be used vertically or at an angle?
    • Where can I find all of the open-source designs for the LongMill?
    • Can you make me a larger version of the LongMill?
    • What are the power requirements for the LongMill?
    • Can I buy parts for the LongMill or the LongMill without certain parts in the kit?
    • Can I 3D print my own parts for the LongMill?
    • I am having an issue with my machine and need help! How can I get support?
    • What is the warranty on my LongMill?
    • Where are the parts for my machine made?
    • What size is the LongMill?
    • What are the system requirements to use the LongMill?
    • What router should I get and what size router mount do I need?
    • Can I add a laser onto the LongMill?
    • Do I need an internet connection or wifi to run my machine?
    • What comes in the LongMill Kit? Is there anything else I need?
    • What is the accuracy and precision of the LongMill?
    • What parts of the LongMill will require replacing?
    • Can I add a 4th axis to the LongMill?
    • Can I make the LongMill more rigid so I can cut thicker and harder materials?
    • Can I use an alternative router instead of the Makita?
    • What is the maximum feed rate for the LongMill?
    • How long does it take to assemble the LongMill?
    • What do I need to order with my LongMill? What should I budget?
    • Why don't you put the lead screws on the Y-axis on the inside instead of the outside on the LongMill?
    • Why is the LongMill so much more affordable than your competitors?
    • Is there anyone near me that can give me a demo on their LongMill?
    • What is the lead time on the LongMill?
    • What is the difference between the LongMill MK1 and the LongMill MK2?
    • Can the LongMill cut metals?
    • Can the LongMill be run or stored in the cold/heat?
  • Shop Info
    • There is a lead time on some of your products? Is there any way to get that item sooner? Are they accurate?
    • What currency is your store in?
    • When do you take payment for my order?
    • Do you have any discounts?
    • Do you provide discounts for organizations, educational facilities, makerspaces, military personnel, influencers, etc?
    • Can I return a product or receive a refund?
    • Do you have a distributor for the LongMill? Where can I buy a LongMill?
    • Where can I find my order number?
    • I am a Canadian First Nations person with tax-exempt status. Can I have my taxes exempt on my purchases?
    • Do you offer financing?
    • Do you have any coupons for your store?
    • What is the LaserBeam?
    • Who is the LaserBeam for?
    • How powerful is the LaserBeam?
    • What does the LaserBeam come with?
    • Who is Sienci Labs?
    • How can we get in touch?
    • Can I come visit your office?
    • Who is that white dog?
    • Do you do sponsorships?
    • Do you offer workshops?
