gSender v1.5.7 Release
New gSender version available
We’re excited to announce the release of gSender v1.5.7, a version focused on refining performance, fixing long-standing quirks, and adding new functionality to make your CNC workflow smoother than ever.
Check below for a full list of changes. Updates are available via Github or follow the update prompts in-app on gSender startup.
v1.5.7 Changelog
  • Fixed issue with start job shortcut not firing in some situations.
  • Park shortcut now persists between sessions.
  • Unlock button now has same logic as large Alarm unlock button for Alarm 10 and 17 where it will reset and unlock for you.
  • Corner selection hidden for Z-only probe type.
  • Squaring tool calculations for custom distances are now correct.
  • Added support for Teensy boards in recognized devices.
  • Error line reporting mismatch fixed.
  • Stopping on start event codes should now correctly clear the planner and reset the board.
  • Added cut depth validation to Surfacing tool.
  • Auto-reconnect should work for Ethernet again.
  • Added import/export functionality for gamepad profiles.
  • Homing location now shows correctly on stats page.
  • Fixed issue with terminal history order.
  • Added new config option to run check on a file when it’s loaded in.
  • Fixed issue with rapid position shortcuts not memoizing positions.
  • GRBL spindle max/min again correctly updates the eeprom on change.
  • Config search behaviour updates to be more consistent with modified flag enabled.
  • Probe shortcut no longer causes an error 2 due to stale distance modal.
  • Rapid position shortcut no longer has a stale homing location value.
Download
gSender v1.5.7 can be downloaded from Github:
https://github.com/Sienci-Labs/gsender/releases/tag/v1.5.7
