Hey folks. gSender 1.1.3 has been released with firmware tool improvements, input improvements, and bug fixes/feature improvements!
The firmware tool has a new look – settings different than the default for your selected machine profile are highlighted, you can easily look up settings by term rather than number, and machine profile is now located inside the tool instead of in preferences. We’ve also added some new machine profiles for Longmills with extension kits and some other machines.
Machine profile selection has been removed from preferences entirely. The purpose of machine profiles has been gradually lessened over each release, and the only part of the program it was still informing was the firmware tool. Due to this, we’ve removed it from preferences as a selection since it’s purpose was confusing a number of users, especially when it came to machine dimensions (which were actually pulled from EEPROM). Machine profile is now selected in the firmware tool, and only handles which image to flash/settings to use as default values.
We also have a number of feature improvements, including: UI inputs also no longer default to minimum value if the user takes longer than expected to type, Test File mode now restores WCS upon completion, and continuous jogging working more consistently when $13 (report in inches) is enabled.
Patch Notes
- Added profiles for Longmill extension kits
- Machine profile removed from preferences and placed in firmware tool
- Fixed incorrect default values in some machine profiles
- Test mode now restores WCS after the soft reset performed while exiting check mode.
- Fixed issue with test mode that would occasionally have it start running the file after test was complete
- Fixed issue with continuous jog when soft limits were enabled and report in inches EEPROM value was enabled
- Firmware tool improvements – new convenient profile selection, setting search, performance improvements, highlighted changed values
- Improvements to value inputs – should no longer default to min value if there is too long a pause in typing
- Surfacing labels changed to X/Y rather than length/width
- Minor styling changes
gSender 1.1.3 Assets: Release 1.1.3 · Sienci-Labs/gsender 8
