Everything you need to get to for starting CNCing with your LongMill
The Must-Have CNC Tools for Beginners
The LongMill
What is a CNC Machine?
  • Are looking to do this as a hobby, with some interest in production and business work
  • Need high-quality resources and support
  • Willing to make a small compromise in cutting speed but still be able to produce the same type of work as more expensive machines
  • To make products that are affordable for the average hobbyist
  • Provide resources, support, and instructions so that we can make sure our customers can be successful in using our products.
All You Need To Know To Start Your Journey With Your LongMill
Router or Spindle
End Mills and Bits
What are End Mills and Which Ones Do I Choose?
A Guide to Collets and CNC Router Tools
Bench
How to Build a Bench and Install T-Tracks for You Longmill Setup?
Computer and Software
What is a G-Code Sender or CNC Machine Interface?
How to setup gSender Edge to use your CNC machine remotely
Which software should you use to run your first CNC project on your LongMill?
Dust Collection
Magnetic Dust Shoe for the LongMill MK2
Work Holding
Make Your Own CNC Workholding With Your CNC Machine
Introducing the New AutoZero Touch Plate!
How to Install Limit Switches onto Your LongMill MK2 CNC
Enabling the Inductive Sensors for the LongMill CNC from Sienci Labs
Other Accessories
Introducing the Vortex Rotary Axis
Maintenance Items
Conclusion
