The LongMill
Product on sale
LongMill Benchtop CNC MK2.5$1,139.00 – $1,659.00
Router or Spindle
Makita 1.25HP Router$119.99
End Mills and Bits
Starter End Mill Set$42.99 -
Sign Maker End Mill Set$60.99 -
3D Carver End Mill Set$60.99 -
Machinists End Mill Set$64.99
End Mills & Bits
All our bits are designed and tested specifically for CNC routers and spindles.
Bench
Computer and Software
Vectric VCarve Pro V12$699.00 -
Carveco Maker Subscription$0.00 -
Vectric VCarve Desktop V12$349.00
Dust Collection
Work Holding
AutoZero Touch Plate$85.99 -
Touch Plate$27.99
Other Accessories
Vortex Rotary Axis$78.99 – $514.99
Maintenance Items
Conclusion
