The LongMill
LongMill Benchtop CNC MK2.5$1,359.00 – $1,879.00
Router or Spindle
Makita 1.25HP Router$119.99
End Mills and Bits
Starter End Mill Set$43.99
Sign Makers End Mill Set$61.99
3D Carver End Mill Set$61.99
Machinists End Mill Set$65.99
We supply a wide variety of high-quality cutting tools and end mills for CNC machines including v-bits, upcut and downcut bits, and ballnose end mills.
All our bits are designed and tested specifically for CNC routers. Find tool libraries, settings, and feeds and speeds at https://sienci.com/tool-libraries/
Bench
Computer and Software
Vectric VCarve Pro V12$699.00
Carveco Maker Subscription$0.00
Vectric VCarve Desktop V12$349.00
Dust Collection
Work Holding
34″ T-Track Set$13.99 – $102.99
AutoZero Touch Plate$87.99
Touch Plate$27.99
Other Accessories
Vortex Rotary Axis$80.99 – $524.99
Sienci LaserBeam Laser System$335.99
Maintenance Items
Conclusion
