Hey Folks,
We have yet another gSender release for everyone that mainly addresses some of the reported problems over the past two months.
New Additions
- Probe corner selection is back. After some requests to bring the feature back, we decided a good middle ground would be to add it as a setting on the config page. This way, users have the option to customize the behaviour, while reducing the chances you are selecting the wrong option.
Improvements
- Firmware settings now have minimum and maximum values, preventing you from setting an out-of-bounds value
- The diagnostics PDF has an improved layout when displaying the config settings
- Park, Go To Location, Quick Movement, and the TLS manual tool change position now raise Z by the pull-off distance ($27) when the $22 bit 3 is off, instead of a fixed Z-1
Fixes
- An issue with unit conversion on manual and semi-automatic tool change when $13 is enabled
- The diagnostics PDF was reporting stale firmware values previously
- An issue with surfacing plunging into the board when selecting the center start position has been resolved by running the Z retraction move before the X and Y axis move to the starting position
- General bug fixes and stability improvements
Download
As always, gSender can be downloaded via GitHub:
