The LongMill
Router or Spindle
- Makita 1.25HP Router$165.00
End Mills and Bits
- Starter End Mill Set$60.00
- Sign Maker End Mill Set$85.00
- 3D Carver End Mill Set$85.00
- Machinist’s End Mill Set$90.00
End Mills & Bits
All our bits are designed and tested specifically for CNC routers and spindles.
Bench
Computer and Software
- Vectric VCarve Pro V12$896.00
- Carveco Maker Subscription$0.00
- Vectric VCarve Desktop V12$460.00
Dust Collection
Work Holding
- AutoZero Touch Plate$120.00
- Touch Plate$35.00
Other Accessories
- Vortex Rotary AxisPrice range: $110.00 through $720.00
Maintenance Items
- T12 Delrin Anti-Backlash Block$11.00
- T8 Delrin Anti-Backlash Block (4pcs)$18.00
- Delrin V-Wheels (12pcs)$21.00
Conclusion
