Home / What is the accuracy and precision of the LongMill?
Frequently Asked Questions
  • Frequently Asked Questions
  • What is the accuracy and precision of the LongMill?
You can expect around +/- 0.1 to 0.2mm for the accuracy of your machine. This may vary depending on your material and your feeds and speeds. For general woodworking, the LongMill is more than accurate enough.
For additional data and information, please see this article https://sienci.com/2022/09/09/stiffness-and-deflection-testing-on-the-longmill-mk2/
Previous Article
What comes in the LongMill Kit? Is there anything else I need?
Next Article
What parts of the LongMill will require replacing?
    • What is the largest spindle that I can put on the AltMill?
    • What is the warranty on the AltMill?
    • What is the AltMill?
    • What are the differences between the AltMill and the LongMill?
    • Has my AltMill shipped?
    • What are the power requirements for the AltMill?
    • What add-ons are compatible with the AltMill?
    • Does the AltMill come with the SuperLongBoard?
    • Do you have a trade-in program to upgrade from the LongMill to AltMill?
    • Can the 1.5KW ER20 Spindle work on the LongMill MK2?
    • I would like to source my own spindle, what should I be aware of?
    • What motors are on the AltMill, and can they be adapted to the LongMill MK2?
    • What is the size and cutting area of the AltMill?
    • Does the AltMill come with a bench/table legs?
    • What computer should I get?
    • What software is compatible with the AltMill?
    • I just ordered a LongMill! How can I get an update on when it will ship?
    • I have never used a CNC machine before? Will I be able to learn how to use it?
    • What software comes with the LongMill? What software can I use?
    • Can the machine be used vertically or at an angle?
    • What are the power requirements for the LongMill?
    • Can I buy parts for the LongMill or the LongMill without certain parts in the kit?
    • Can I 3D print my own parts for the LongMill?
    • What is the warranty on my LongMill?
    • Where are the parts for my machine made?
    • What size is the LongMill?
    • What are the system requirements to use the LongMill?
    • What router should I get and what size router mount do I need?
    • Do I need an internet connection or wifi to run my machine?
    • What comes in the LongMill Kit? Is there anything else I need?
    • What parts of the LongMill will require replacing?
    • Can I add a Rotary/4th axis to the LongMill?
    • Can I make the LongMill more rigid so I can cut thicker and harder materials?
    • Can I use an alternative router instead of the Makita?
    • What is the maximum feed rate for the LongMill?
    • What do I need to order with my LongMill? What should I budget?
    • Why don't you put the lead screws on the Y-axis on the inside instead of the outside on the LongMill?
    • Why is the LongMill so much more affordable than your competitors?
    • Is there anyone near me that can give me a demo on their LongMill?
    • Can the LongMill cut metals?
    • Can the LongMill be run or stored in the cold/heat?
    • Can I increase the Z height or travel on the LongMill?
    • Should I buy a used LongMill? What should I be looking out for when buying a LongMill second-hand?
    • What is the Vortex Rotary Axis?
    • Which machines are the Vortex Rotary Axis compatible with?
    • How is the Rotary Axis driven?
    • Does the Vortex Rotary Axis come with software?
    • What is the cutting volume of the Vortex Rotary Axis?
    • What's the difference between the 48in and 30in versions for the Vortex Rotary Axis?
  • Shop Info
    • There is a lead time on some of your products? Is there any way to get that item sooner? Are they accurate?
    • What currency is your store in?
    • When do you take payment for my order?
    • Do you have any discounts?
    • Do you provide discounts for organizations, educational facilities, makerspaces, military personnel, influencers, etc?
    • Can I return a product or receive a refund?
    • Do you have a distributor for the LongMill? Where can I buy a LongMill?
    • Where can I find my order number?
    • I am a Canadian First Nations person with tax-exempt status. Can I have my taxes exempt on my purchases?
    • Do you offer financing?
    • Do you have any coupons for your store?
    • The LongMill says it's "made to order" but also that it's "in stock". What does that mean?
  • Shipping
    • Where do you ship to?
    • Can I pick up orders from your office?
    • What are duties and taxes and how much should I expect to pay?
    • What is the size and weight of the LongMill in its package?
    • Why are some parts of my order separate or split up?
    • How can I get a shipping estimate?
    • How can I change, add, or modify an existing order?
    • Can I put a hold on a shipment?
    • Why do I need to provide my SSN, TIN, or EIN for US Customs?
    • Who is Sienci Labs?
    • Can I come visit your office?
    • Who is that white dog?
    • Do you do sponsorships?
    • Can I give you a suggestion for a product or feature?
    • Who is the LaserBeam for?
    • How powerful is the LaserBeam?
