The LongMill
LongMill Benchtop CNC MK2.5$1,359.00 – $1,879.00
Router or Spindle
Makita 1.25HP Router$119.99
End Mills and Bits
Starter End Mill Set$43.99
Sign Maker End Mill Set$61.99
3D Carver End Mill Set$61.99
Machinists End Mill Set$65.99
Bench
Computer and Software
Vectric VCarve Pro V12$699.00
Carveco Maker Subscription$0.00
Vectric VCarve Desktop V12$349.00
Dust Collection
Work Holding
34″ T-Track Set$13.99 – $101.99
AutoZero Touch Plate$86.99
Touch Plate$27.99
Other Accessories
Vortex Rotary Axis$79.99 – $521.99
Maintenance Items
Conclusion
