The LongMill
					Product on sale LongMill Benchtop CNC MK2.5$1,139.00 – $1,659.00 LongMill Benchtop CNC MK2.5$1,139.00 – $1,659.00
Router or Spindle
					 Makita 1.25HP Router$119.99 Makita 1.25HP Router$119.99
End Mills and Bits
					 Starter End Mill Set$42.99 Starter End Mill Set$42.99
					 Sign Maker End Mill Set$60.99 Sign Maker End Mill Set$60.99
					 3D Carver End Mill Set$60.99 3D Carver End Mill Set$60.99
					 Machinists End Mill Set$64.99 Machinists End Mill Set$64.99
Bench
Computer and Software
					 Vectric VCarve Pro V12$699.00 Vectric VCarve Pro V12$699.00
					 Carveco Maker Subscription$0.00 Carveco Maker Subscription$0.00
					 Vectric VCarve Desktop V12$349.00 Vectric VCarve Desktop V12$349.00
Dust Collection
Work Holding
					 AutoZero Touch Plate$85.99 AutoZero Touch Plate$85.99
					 Touch Plate$27.99 Touch Plate$27.99
Other Accessories
					 Vortex Rotary Axis$78.99 – $514.99 Vortex Rotary Axis$78.99 – $514.99
Maintenance Items
Conclusion
